There are only a few things that need to get changed.
Part 1:
Block Start = line .*
Matches the expression = line (.*)
Part 2:
Previously Matched Blocks
Matches the expression = exec-timeout (.*) (.*)
***** We have to add the extra (.*) to store the second value. The exec-timeout command if configured has two values*****
exec-timeout 15 0
So we have to account for there being another value after what we want to capture. If we didn't do this the value that would be stored would be:
15 0 instead of just 15
Part 3:
Evaluate Expression = <2.1> > 10
In Part one if it matches continue, if it doesn't match select "Does Not Raise Violation"
In Part two if it matches continue, if it doesn't match select "Raise a Violation and Continue"
In Part three if it matches continue, if it doesn't match select "Raise a Violation and Continue"
Hope this helps
Brett
