PI install 3.0.2
After upgrading tp PI-VA-3.0.0.0.78.ova.zip . How to install the DevicePack 3.0.2 ? And where to download it ?
This one first pi302-16.ubf
6 Replies 6
Mark Malone
Hey do it directly from the GUI
go to this section once its online it will see what updates and patches are available and you can install directly, I have 3.0.2 installed for critical fixes
Administration / Licenses and Software Updates / Software Update
but witch one i need to download from this link ?
https://software.cisco.com/download/release.html?mdfid=286285348&flowid=76142&softwareid=284272933&release=3.0.2&relind=AVAILABLE&rellifecycle=&reltype=latest
thank you
One more question
Do we first download the device pack and then the patch ? or vice versa ?
This is what I have installed on my PI3.0 device pack 1 and 2 and then my critical fixes , pout device pack in first
