PI ncs cleanup command
CCC3
Level 5
Level 5
PI's opt/var is full, so accessing the GUI is not possible.
I looked it up and it seems that running ncs cleanup will clear up opt's capacity.
When using this command, you need to check whether the maps or devices set on the pi are also reset.
And if you use that command, does your account sometimes get lost?
Mark Elsen
 - Your  account will not get lost , neither maps or devices,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
