PI : Where devices archive files are located ?
mmisonne
Level 2
Level 2
Hello
With LMS we can find the device config file in  CSCOpx/file/rme/dcma.
Do you knows where those files are archived with Prime ?
Michel Misonne
Rollin Kibbe
Hi Mmisonne:
The config archives are not currently user accessible in Prime Infrastructure.  Bug CSCud84458 has been filed asking that an LMS-like shadow directory be made available, but as of 1.3.0.20, that hasn't been implemented yet.  The configs are stored as binary blobs in the Oracle database.
You're certainly welcome to open a service request with the TAC to have your service request linked to that bug, and the TAC engineer should be able to follow an internal process to write out those blobs, but it would only be a one time event;  you wouldn't have access to new config files every day.
I'd suggest signing up for notifications on CSCud84458.
9 Replies 9
Rob Johnson
the files are written to the localdisk in the /tftp directory...
Yes, but in this directory, I can see only Wifi-controllers files, not switch files .
Directory of disk:/tftp
      19354 Jun 20 2013 18:30:50  10_13_255_86_130620_1830.cfg
      19354 Jun 20 2013 23:30:50  10_13_255_86_130620_2330.cfg
      10289 Jun 20 2013 18:30:24  10_13_255_87_130620_1830.cfg
      10289 Jun 20 2013 23:30:24  10_13_255_87_130620_2330.cfg
           Usage for disk: filesystem
                 6256558080 bytes total used
                22627086336 bytes free
                30455668736 bytes available
frpropri21/admin#
Michel Misonne
I'm bumping up this thread because I am running into the same issue in Prime Infra 2.0
Were there no evolutions on this situation ? I can't see any config files in the disk:/tftp folder or any other folder.
Is there a way maybe to redirect those backup configurations towards an external server ? via FTP? There used to be a way to do that with LMS.
This is still an issue with PI. Browsable directory. An enhancement is filed and is being worked upon #
CSCud84458- Need separate folder for config archives to be stored on NCS/PI .
-Thanks
Vinod
**Enourage Contributors. RATE them**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
I have the same issue. Using PI2.1, looked everywhere but couldn't find the configuration files. Most likely they are stored in a database.
Quick question, I have a couple of hundred devices and need to transfer all the lastest devices' config to another place. I don't want to save device config one by one in GUI. If there a way to run a task to get the last config for each device?
Thank you.
Robert
I would recommend you to open a TAC case and get a script from them which can copy the latest configurations from Oracle DB and dump it to a directory.
Not sharing the script and process here as it is a controlled process and not official yet.
-Thanks
Vinod
Rollin Kibbe
Hi Mmisonne:
@mmisonne the xml file is accessible
We have Prime 3.1 and we were able to access it, through the linux shell
type: shell (to get to the linux shell)
once there, you can locate the xml under this route
/opt/CSColumos/conf/rfm/classes/com/cisco/common/ha/config/haSettings.xml
Voila. Enjoy!!!!!!!!!!!!
mtenorio
