11-21-2012 03:00 AM
Im on evaluating PI1.2 in Lab environment with only few devices. To be able for using our ESX-HA settings and to avoid huge storage wasting, I installed PI using the iso-image instead of the ova-template with just 100GB of storage instead of 256GB.
For this environment its much more than enough storage, but the GUI complains about low disk space in /opt (11GB free) regulary. To avoid this message I want to ask, where I can lower this filesize thresholds in PI1.2?
Many thanks for your hints, Steffen
Solved! Go to Solution.
11-21-2012 01:27 PM
Steffen,
I do not think that you could change the settings according to this document
it says that there is a 50% threshold and it is hard set....
11-21-2012 01:27 PM
Steffen,
11-22-2012 04:11 AM
thx Martin for this very good document from the Wireless forum.
What Im thinking about: What will the future be with this forum when LMS will die and replaced by PI completely in more than one year?
Will PI be handled in the wireless forum or this one?
