05-15-2024 01:12 AM
Hi, I have a PC win 10 VMware connect to router. but i can ping to this pc (lost a lot packet). I think my problem related to firewall on PC Vm NOTE: DMZ (192.168.91.250) -----> WINdown (192.168.91.2) - default get (192.168.91.2)
DNS server in DMZ
ip name-server 192.168.91.2. i choose because VM net 1 host only is 192.168.91.0
05-15-2024 04:15 AM
can you post the running config (sh run) of the DMZ router, as well as the output of 'ipconfig /all' from the Windows 10 machine ?
05-15-2024 05:53 AM
Building configuration...
Current configuration : 1954 bytes
version 12.4
hostname DMZ
boot-start-marker
boot-end-marker
enable password 123
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip domain name thien.vn
ip name-server 192.168.27.2
ip name-server 8.8.8.8
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username thien password 0 123
ip tcp synwait-time 5
ip ssh version 1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 4.0.0.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
interface FastEthernet2/1
interface FastEthernet2/2
interface FastEthernet2/3
interface FastEthernet2/4
interface FastEthernet2/5
interface FastEthernet2/6
interface FastEthernet2/7
interface FastEthernet2/8
interface FastEthernet2/9
interface FastEthernet2/10
interface FastEthernet2/11
interface FastEthernet2/12
interface FastEthernet2/13
interface FastEthernet2/14
interface FastEthernet2/15
interface Serial3/0
no ip address
shutdown
serial restart-delay 0
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 3.0.0.2
ip route 0.0.0.0 0.0.0.0 4.0.0.254
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login local
transport input ssh
end
05-15-2024 05:56 AM - edited 05-15-2024 06:32 AM
i received 1 when sent 4 packet
