Ping Results to a Notepad
sajidafridi45
Dear Experts,
is there any way i can send ping results to a notepad from a cisco router or switch?
thanks in advance
Sajid
Phillip Remaker
Can you be more specific about what you want?  If you mean the Microsoft Windows Notepad Editor, what you are really asking for is a way to create a text file on a PC from ping results collected on a router
The quickest solution is to cut and paste the result from your favorite terminal emulator.
If you want automation and scripting, any number of terminal emulation tools can do that as can windows powershell scripts.  Also, many newer routers have TCL scripting capabiltiies built in as well.  There are also lots of automation tools from various vendors.  There are a number of ways to solve the problem, but you need to be more specific about your problem.
