Pitney Bowes Printer and Cisco 9300 Series switches
terry.briscoe
Attempting to use a Putney Bowes Postage meter printer Model 8H00  to connect to our Cisco 9300 switch using the built in wired connection on the device.    Cisco Switch is  PID: C9300-48UXM and running version 17.06.05.   When attempting to connect the device we go through the setup and select wired  and dhcp  setting.   the device gets a connection  I see the mac but then it drops off and the link closes Port is configured as follows.    Has anyone had issues with these printers and 9300 switches?
interface TwoGigabitEthernet1/0/19
description Pitney Bowes
switchport access vlan 100
switchport mode access
switchport voice vlan 800
device-tracking attach-policy IPDT_POLICY
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AutoQos-4.0-Trust-Cos-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
end
6 Replies 6
marce1000
 - Why do you have voice vlan in that particular port configured ; for starters I would try with a minimum (but needed) port configuration as in :
         end
 M.
just a thought: try and hardcode the wired MAC address:
switchport port-security
switchport port-security mac-address 00:A0:C4:AB:C0:3E
Leo Laohoo
"UXM" means some ports are mGIG-capable.
Move that connection to a GigabitEthernet-only port.  mGIG ports means it will not support 10 Mbps and this printer may need 10 Mbps for channelling &/or signalling purposes.
terry.briscoe
Suspect that the Pitney Bowes is unable to negotiate with the multi gig interface on the switch. There are only the two gig and the 10 gig interfaces on this model switch.  The connection was on a two gig connection.    We did try to force speed and duplex and none worked to get the printer to connect.     For now what we have done is used an old Cisco phone as the connection to the switch and we are using the output of that to the printer.   For now that is the workaround and working.    that is why we left the phone configuration in place as well.      Thanks for the help.   Was hoping to not have to use a proxy device to get this to work,  but as least we have a way for now.
Networking and connectivity details for the SendPro C Lite, SendPro C, SendPro +, SendPro C Auto | Pitney Bowes Support
mentions: Wired Ethernet supports 10/100 Mbit speeds.
the C9300-48UXM : spports 48 port Cisco UPOE, 36 ports 100M/1G/2.5G + 12 ports Multigigabit (10G/5G/2.5G/1G/100M)
-> the switchports are 100M capable, if you set the speed fixed at 100M at both sides (not only at the switch side) it should work
you may also need to set "no autonegotiate" at the switchport
That confirms that 10 Mbps is needed and plugging into an mGIG port is not going to work.
