Point Catalyst 4506 syslogs to 10.x.x.x
Sencyty
Need to send all 4506 switch syslogs to be sent to 10.x.x.x over UDP port 514 can anyone help me with full details on how to get this done ASAP with explanation.
Thank you
balaji.bandi
config terminal
logging host 10.x.x.x or logging 10.x.x.x
Depends on what logs to send syslog follow below guide :
https://community.cisco.com/t5/networking-documents/how-to-configure-logging-in-cisco-ios/ta-p/3132434
BB
6 Replies 6
balaji.bandi
config terminal
BB
Thank you Balaji but can same command be use on Nexus 9k switch please?
I do appreciate thank you
Nexus i use like this :
logging server X.x.x.x 4
logging server y.y.y.y  4 use-vrf  MGMT
logging server host [ severity-level [ facility ]]
Level of Log you want to send :
Table 1-1 System Message Severity Levels
Level
Description
0 – emergency
System unusable
1 – alert
Immediate action needed
2 – critical
Critical condition
3 – error
Error condition
4 – warning
Warning condition
5 – notification
Normal but significant condition
6 – informational
Informational message only
7 – debugging
Appears during debugging only
BB
the command:
logging host 10.X.X.X transport udp port 514
might or might not be available on your 4500...
