Policy-map
How do i insert new class map entry in an existing policy map on cisco isr 4K? requirement is to have the new class map entry on the top.
Sridhar
balaji.bandi
Can you post your policy map and explian what class-map you like to add ?
so we can suggest best syntax to make it work.
example : ( make sense ?)
# policy-map company_policy
   class icmp_class   - 1
      inspect icmp
   class ratelimit_class -2
     police input xxx xxxx
BB
PFB, i want to insert new class map between L3-to-L2_VoIP-RTP and  Class filecopy.
Policy Map Voice_mpls
Class L3-to-L2_VoIP-RTP
priority 30000 (kbps)
Class filecopy
police cir 7600000 bc 237500
conform-action transmit
exceed-action drop
bandwidth 7168 (kbps)
Class L3-to-L2_VOIP-Cntrl
bandwidth 512 (kbps)
Class class-default
fair-queue
queue-limit 1024 packets
