05-28-2020 03:04 AM
hi im in the middle of learning the ccna and i want to know
1. can different port channel be with the same number and if so, should i do it and what if i dont want to get comfused
can i put all my port channel that i have in the same number
2. same question about ether channel, can i do it and should i
thank for the help (:
05-28-2020 03:50 AM
05-28-2020 05:17 AM
thanks for the responde
but if Port channel and Ether channels are the same so why in the configuration there is "int port channel ID" (for portchannel) and "channel-group ID mode on" (for etherchannel)
by the way do recommend to give the same ID to Port channel and to Ether channels
sorry if these question a bit stupid i just want to be sure what im doing
05-28-2020 04:44 AM
05-28-2020 11:23 PM
