12-25-2021 02:59 AM
Hello, I want to access a PaBx (172.16.0.86) so I tried to do port forwarding for it in Isr4221 but still can't reach it.
When I do port check on the public ip, it still shows that the port(80) is closed.
What more should I do.
12-25-2021 09:11 AM
does GigabitEthernet0/0/1 have an actual IP address ? If so, try and change the entry to:
ip nat inside source static tcp 172.16.0.86 80 x.x.x.x 80
12-25-2021 11:55 PM
Hello @Georg Pauwen
GigabitEthernet0/0/1 has a public ip.
I also tried using the public IP in place of the interface name but still was not successful.
12-26-2021 12:33 AM
can you post the output of:
sh ip nat portblock dynamic global
show ip nat portblock pat global
12-26-2021 12:42 AM
Here it is
YH-Cisco-Router#sh ip nat portblock dynamic global tcp: 5062 -6085 rfcnt 1 545 -617 rfcnt 1 udp: 5062 -6085 rfcnt 1 585 -648 rfcnt 1 512 -584 rfcnt 1 YH-Cisco-Router#show ip nat portblock pat global tcp: 80 rfcnt 1 YH-Cisco-Router#
12-26-2021 12:58 AM
I have also forwarded it on udp but still the same problem
YH-Cisco-Router#show ip nat portblock pat global tcp: 80 rfcnt 1 udp: 80 rfcnt 1 YH-Cisco-Router#
12-26-2021 03:07 AM
try the below:
Delete both NAT entries:
no ip nat inside source static tcp 172.16.0.86 80 interface GigabitEthernet0/0/1 80
no ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
Then clear the NAT translations:
clear ip nat translation *
Then re-add the NAT entries (static first):
12-27-2021 02:03 AM - edited 12-28-2021 12:23 AM
not successful yet
YH-Cisco-Router#sh ip nat translation Pro Inside global Inside local Outside local Outside global tcp X.X.X.X:443 172.16.0.254:443 --- --- udp X.X.X.X:80 172.16.0.254:80 --- --- tcp X.X.X.X:80 172.16.0.254:80 --- --- udp X.X.X.X:539 172.16.0.11:123 132.163.97.4:123 132.163.97.4:123 tcp X.X.X.X:5309 172.16.0.56:35118 216.58.223.86:443 216.58.223.86:443 tcp X.X.X.X:5366 172.16.0.56:43326 172.217.170.206:443 172.217.170.206:443 udp X.X.X.X:517 172.16.0.13:123 132.163.97.1:123 132.163.97.1:123
I did what you said and still not successfull.
172.16.0.254 is a PaBx whic I want to access and connect telephones from another branch
X.X.X.X is the public IP of the cisco ISR4221
The hhtp port of the PaBx is 80
https port of the PaBX is 443
