port scan tool
iqbalkhan
I need check my network to see open port.
I need suzzation for good tools.
thanks
biplob
pkhatri
Level 11
Level 11
Here's a link to a site with some free port scanners:
http://netsecurity.about.com/cs/hackertools/a/aafreeportscan.htm
Hope that helps - pls rate the post if it does.
Paresh
I install nmap , I heard it usefull.
but I do not know which are the usefull command. can u help me.
That's a pretty broad request. A lot depends on what you are trying to scan for and for how broad a range of devices and/or ports...
Here's the online docs - there are several examples that should help.
http://www.insecure.org/nmap/man/index.html
