Port Security Issue
Ayman Najdi
I have a POE Switch  C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E5. I have configured on a certain port voice and access VLAN. I have a cisco phone connected to this port and a PC connected to the IP phone. I also configured port security based on sticky mac-addresses.
Following is the configuration:
interface GigabitEthernet1/0/4
switchport access vlan 21
switchport mode access
switchport voice vlan 60
switchport port-security maximum 2
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
switchport port-security mac-address sticky
switchport port-security mac-address sticky 7427.ea66.4875
switchport port-security mac-address sticky 0027.9081.1224 vlan voice
spanning-tree portfast
end
The problem is as following, when setting the port-security maximum to '2' which i'm assuming is mandatory in my case to handle two devices on the same port, I tried to plug another PC and then the MAC value '7427.ea66.4875' was overridden by a new MAC belonging to the new PC. No violation was triggered! the new PC gained access over the network normally, this contradicts the entire concept of port-security. How can i overcome this security gap? Am i configuring something wrong? Is there any suggested best practice for configuring port-security over a physical port hosting two devices (IP phone & PC) in different Vlans (Voice and access) ?
5 Replies 5
Larry Sullivan
Level 3
Level 3
Cancel
Deepak Kumar
Please check what is volition available on the port? As I know that default volition is "Shutdown".
show port-security interface GigabitEthernet1/0/4
Try with  "switchport port-security violation {restrict | shutdown}" command under the interface.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi, Thanks for your input,
I issued the show command. It shows that the violation mode is shutdown, I believe this is the default behavior without needing to define it.  I tried issuing all kinds of violations and still getting the same result, nothings happens except the new MAC address overwrites the old one. Very weird :(
Port Security              : Enabled
Port Status                : Secure-up
Violation Mode             : Shutdown
Aging Time                 : 0 mins
Aging Type                 : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses      : 2
Total MAC Addresses        : 2
Configured MAC Addresses   : 0
Sticky MAC Addresses       : 2
Last Source Address:Vlan   : 701f.5387.335f:60
Security Violation Count   : 0
is there any error disable recovery configured?
Deepak Kumar
Deepak Kumar,
errdisable recovery is not configured
HO-Switch-112(config)#do sh errdisable recovery
ErrDisable Reason            Timer Status
arp-inspection               Disabled
bpduguard                    Disabled
channel-misconfig (STP)      Disabled
dhcp-rate-limit              Disabled
dtp-flap                     Disabled
gbic-invalid                 Disabled
inline-power                 Disabled
link-flap                    Disabled
mac-limit                    Disabled
loopback                     Disabled
pagp-flap                    Disabled
port-mode-failure            Disabled
pppoe-ia-rate-limit          Disabled
psecure-violation            Disabled
security-violation           Disabled
sfp-config-mismatch          Disabled
small-frame                  Disabled
storm-control                Disabled
udld                         Disabled
vmps                         Disabled
psp                          Disabled
dual-active-recovery         Disabled
evc-lite input mapping fa    Disabled
Recovery command: "clear     Disabled
