port utilization percentage
jeremyczaicki
Hi everyone,
I am looking for a way to call telnet command line to get all ports bandwidth utilization as a percentage. I use SG350.
thank you !
balaji.bandi
You can use SNMP with NMS or you can use scripting to do what you looking for.
BB
jeremyczaicki
i have find out the solution : "show switchport monitor utilization"
sure that gives you the current data, if you looking statistics for Long that not give accurately that is the reason suggested to have NMS.
if only require for the current time hope that works.
BB
