11-04-2005 06:49 AM
I would like to monitor the usage of our 3 PRI lines that come into our Cisco 2821 router so that I can determine if we need all 3 lines. How would I go about doing this? The goal to create a line graph to show the peak times of usage and how many calls there were. I know that each of our PRI lines have 24 channels so I'm thinking that if we aren't using at least 48 of those channels then I would drop a PRI. Thanks for the help.
11-04-2005 08:12 AM
U can try Solarwinds which can get u all the graphical as well as tabular description of the usage and the bandwith gauges can get u the actual load at all times.
Hope it helps..
11-04-2005 02:32 PM
I'll keep that in mind but I was thinking more along the lines of using SNMP to get the information. I have Intuit's Network Monitor that can graph out any MIB SNMP object and would like to show in a graphical representation of the show voice call sum over a period of a word day. The problem is I don't know which MIB object that would be or what SNMP information that would be.
