Prime 2.1 Configuration Archive - No Vlan.dat from 6504 switches
Carstenlymann
I have a Configuration Archive job running on my prime 2.1
With all my 2960, 3560 swiches there is a vlan.dat file also after the archieve job.
But not from my 6504 switches. As far as i can see vlan.dat is not in same directory on 6504 as the other switches. So thats problably where it all goes wrong. But how do i tell that to prime so prime can get them so i have backup of them in prime as well..
No problem for me if only solution is to make another job just for that. Would just prime to make that archieve automatic like with all others.
Hope someone can help. :)  Thanks
/ Carsten
0 Replies 0
