PRIME 2.2 with Switches 4500
Mohamed Mostafa
Dears,
after discovering the switches 4500 with the PI 2.2 ... and checking the switches in ( Monitor > network devices )
and choose the device ... then it shows ( Device details are not available for the selected device.)
my question is does this is a bug or the is a problem in my software.
thanks
Mohamed Mostafa
AFROJ AHMAD
Hi Mohamed,
device should be supprted ..
is the device show "sucessful inventory " ?
you cab try below action:;
check and installed the latest device pack
try to delete and re-add the device
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Afroj Ahmad,
i tried what you recommanded , i installed the latest device pack and deleted and re-added the device but it didn't solve the problem,
i will try to upgrade the PI to version 3.0
thanks for your kind reply
Mohamed
