I have installed a Prime instance with Version 3.0 in our LAB. I discovered several Devices (Automatioc and manually) and i have full access (SSH and SNMP RW)
The Problem is, that the System will not add an automatic link between two direct connected Devices. When i check the neighbours there is a cdp neighbourship:
Pleas see the situation in the pucture below:
Solved! Go to Solution.
https://supportforums.cisco.com/discussion/12882396/cpi-302-map-topology-links-between-devices-missing
Maybe the same thing?
