Prime 3.0
I'm using PI 3.0 since a few hours. Now I try to run eox report, but I'm not able to configure the settings. Exact version is 3.0.0.0.78
I used this link, Administration / Settings / System Setting. I'm looking for compliance enable, but I can't see it.
Thank you for any help.
regards
Hans
Philipp Kreidl
Hey Hans, had the same issue, found it in quickstart guide.
Compliance checks like EoX reports are only available in the PRO version of Prime Infrastructure. This means you have to setup a ridiculous big VM for.
Source: http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/quickstart/guide/cpi_qsg.html#pgfId-67786
Philipp Kreidl
