Running Prime 3.1 WLC on 8.0.152.
Issue is Keep getting Collection Failure between Prime and 3 * 8510 WLC.
The TELNET/SSH and SNMP are correct as test by Verify Credentials, Readability is Green
I have a 5508 running 8.0.140 & a 2500 running 8.0.121 they are set up the same, everything passes, just seems to be issue with 8.0.152
There are no firewalls blocking, these are on on the same network.
I have removed and re added, this has worked once.
Cheers in advance
