Prime 3.1 Out of sync with WLC
craiglebutt
Level 4
Level 4
Running Prime 3.1 WLC on 8.0.152.
Issue is Keep getting Collection Failure between Prime and 3 * 8510 WLC.
The TELNET/SSH and SNMP are correct as test by Verify Credentials, Readability is Green
I have a 5508 running 8.0.140 & a 2500 running 8.0.121 they are set up the same, everything passes, just seems to be issue with 8.0.152
There are no firewalls blocking, these are on on the same network.
I have removed and re added, this has worked once.
Cheers in advance
marce1000
Check the settings mentioned below : (make sure Wireless Configuration Audit is enabled)
"Administration > System Settings > Background Tasks"  look for Wireless Configuration Audit, this will enable the sync of WLCs system wide and you can alter time and settings there.
M.
