Prime 3.1 - Partial Collection Failure For 4500x and 4500
ithq783ds3
Hello i need your help
i have " Partial Collection Failure" in last inventory Collections status for 4500x VSS and for 4500 WS-C4506  with Prime 3.1 last patches  already installed
PI 3.1.7 Update 03
3.0.0
PI 3.1.7 Maintenance Release
7.0.0
thanks
5 Replies 5
marce1000
 - Hoover over the 'i' icon and also post the reason for the failure.
M.
Hello @marce1000
look at attached file
Any suggestion ?
you can set logging to debug level, start inventory collection and then check in inventory and ifm logs. In most cases you can't be sure where error logs gor a particular issue are stored, so login via CLI, go to /opt/CSCOlumos/logs, copy last logs to new folder and then grab for device name, ip, error message and so on
you can also debug on your device, what prime tries to do - may be you can see there a hint
varusrin
Its a known issue, Bug ID : CSCve93317
The bug is fixed in DP14.
You can go for DP16 to fix the issue.
Refer below link for more information,
https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/release/notes/pi31-device-pack-readme.pdf
