Prime 3.4 to 3.7
Luna99923
I'm currently on Prime 3.4 Patch 11. Is it recommended directly to 3.7 or should I go with an earlier upgrade, such as 3.6?  Any "gotchas" with 3.7?
Thank you
You're good to run straight to 3.7; the upgrade path is valid (https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-7/hardware_install/guide/bk_Cisco_Prime_Infrastructure_3_7_0_Installation_and_Migration_Guide_for_Microsoft_HyperV.html#con_1074413) and there is no reason to ruin your day with continuous installs (especially when each reboot takes FOREVER).
As far as gotchas.. I'm on 3.7 and have no issues. Although, some of the system jobs throw errors arbitrarily, and some of the changes take a minute to get used to (or a week...), it's worth it for the device packs and the support.
Thank you!
