Hi Matt,
Ceating view on any OID or MIB will exclude the MIB/OID being polled for this device by any of your monitoring tool.
Yes It will help you to cutdown the CPU utlization of the SNMP process running on the device which overall Impact the cpu utlization of the router.
I know if you have hundrends or thousands of Interface configure on the device then walking or polling IfXtable takes time to complete it which eventually increase the cpu utilzation of the SNMP process.
I recommendation is to reduce the polling frequency to have better performace of the router.
Thanks-
Afroz
[Do rate the useful post]
Thanks-
Afroz
****Ratings Encourages Contributors ****
