04-03-2022 11:20 PM - edited 04-03-2022 11:21 PM
Hi, I'm having issues as an customer have a power switch for a PoE switch where 3 AP's are linked up to, and they're getting turned on/ off multiple times a day. The issues is we have mail notifications set up, and this generates a lot of noise, so I'd like to disable ALL events and alarms for those APs. I've been through Prime documentation but fail to understand if it's even possible?
Solved! Go to Solution.
04-04-2022 12:14 AM
not sure what you have already looked at, but in Prime, you can configure alarm suppression. Have a look at the link below:
04-04-2022 12:14 AM
04-04-2022 12:21 AM
04-04-2022 12:26 AM
that looks good. Hopefully it works as expected...
04-05-2022 10:43 PM
Thanks for your assistance, it worked!
