Prime Infra 3.1 Controller backup
Wireless_Guy
Hi All,
Can someone please guide me how to config prime infra 3.1 to collect controller backup on a scheduled date/time
Hi @Wireless_Guy
 You can do that at:
HI @Flavio Miranda
Thanks for the quick response.
Have you faced any issue when running config archives ? ( controller creds failure - found lot of bugs related to it) Not sure when cisco going to fix it.
> Tested this in lab environment, where I configued the schedule every 10 mins and 20 mins
>Intermittently there will be config archive failure due to controller credentials error
>Controller still shows managed and synced
>Tried increasing  SSH timeout still returns same failure.
Seems like its due to bug : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva57912
Not sure when Cisco is going to fix it
Unfortunately Cisco Prime is very buggy. If you are sure you can a read/write community and proper credentials, then, the only solution is open up a Cisco TAC or wait for future updates.
 Although,  scheduled backup is not difficult to get running script from somewhere. You can get to the WLC, run show running-config and take it to a directory. This would be more reliable.
-If I helped you somehow, please, rate it as useful.-
