Prime Infra 3.1 reporting
mxelkin
I want to report on the ALL the devices in the system.  I specifically need 1. Device Name, 2. IP Address, 3. Product ID, 4. Location.  That's about it.   None of the reports seem to include Product ID which is the MOST IMPORTANT field.  Instead they provide Product Type.  which is too generic.
I upgraded my 3.1 to 3.3, sorry about that..
for what it is worth.. the report you want can easily be done using 3.3 both Custom and Composite Reports.
when you say product ID, give me an example. like below.
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis" PID: CISCO2921/K9 , VID: V05
On the path /Network Devices/ Device Groups / All Devices / "Device Name"
Then System Summary page.
There are 2 columns:
The left column has IP address, Device Name, Device Type, Up Time etc.
The right column has Name, Description, Product ID, Version, Serial Number, ect.
What I want in the report is the field labeled "Product ID" or "Description" in the right column.  NOT the "Device Type" in the left column
