Prime Infrastructure 1.4 problem
sem7433
Hi..
I have just upgraded to Prime Infrastructure version 1.4 and got some problems. Each night nms service will be stopped. I must do ncs stop / start to make it work. Anyone has some ideas ?
/Lasse
AFROJ AHMAD
Hi ,
you can start from here..
Administration  >  Background Tasks
to check for the times tasks are scheduled and for pass/fail status so you can correlate
either trying to run or fail near the time of the crash.
especially look for   Prime Infrastructure Server Backup .
check ths system resouces ,these issue sometimes occurs due to lack of system resources.
Thanks-
Afroz
[Do rate the helpful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Saurav Lodh
Level 7
Level 7
getting nms stopped automatically , can be due to couple of reasons. Open a TAC case if issue is not resolved!!
