Prime Infrastructure 2.0 is not accepting ubf patch file for upload
muddedj
After successfully installing Prime Infrastructure 2.0 on a single server via OVA file in ESX, i tried to install all the latest patches.
- pi_update_2.0-3.zip was installed successful
But for the patch "pi_dev_pack_update_2.0-10.ubf" i was not be able to do the file-upload via the Web-GUI.
Is there anyone who knows how to put this file on the Prime server and how to install this patch via CLI ?
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.6.003-px-build
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: xxxxxxx
Version information of installed applications
Cisco Prime Infrastructure
Version : 2.0.0.0.294
Kind regards,
Danjan Mudde.
AFROJ AHMAD
Hi Danjan,
****These patches cannot be applied via cli and can only be applied from GUI of Prime*****
Go to the link below and download the "pi_dev_pack_update_2.0-10.ubf"
http://software.cisco.com/download/release.html?mdfid=284422771&flowid=45323&softwareid=28
4272933&release=2.0.10&relind=AVAILABLE&rellifecycle=&reltype=all
After downloading the file, go to "Administration > Software Update", click upload update file, browse to the file location that you've downloaded.
Once the file has beenuploaded, you can select the update and click install.
After installing, it shouldindicate "Pending Restart" = Yes.  You will likely need to
go to the cli and do an "ncs stop" and then "ncs start".
Hope it will help
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
Thanks for your reply!. I have checked the link and saw that this is the way i have tried to install the
"pi_dev_pack_update_2.0-10.ubf" file.
After uploading the file, the file won't appear in the list to do the update.
It seems that the Prime application won't accept the file.
I have tried to do a new download but it fails again. I tried to do the upload with different browsers and it fails to.
A restart from the prime server is not the solution.
Hopefully there is someone with a solution for this problem?
Danjan.
anthonykahwati
I am having the same issue that you have described above. Did you get anywhere with this?
Anthony
