Prime Infrastructure 2.0 no 'Add a WLAN' option
twerczynski
Beginner
Beginner
I've started to pay with PI 2.0 and I've noticed that there is no option to add new WLAN.
I am following manual:
Step 1 Choose Configure > Controllers.
Step 2 Click the IP address of the appropriate controller.
Step 3 From the left sidebar menu, choose WLANs > WLAN Configuration.
Step 4 From the Select a command drop-down list, choose Add a WLAN.
but there is no 'Add a WLAN' option. The only ones I've got there are:
Delete WLAN(s)
Schedule status
Mobility Anchors
Foreign Controller Mappings
Does anyone know how to get that option there?
Tomasz
Chris Cummings
Beginner
Beginner
You first need to configure a WLAN template.
Go to Configure - Controller Template Launch Pad
WLANs - WLAN Configuration
Add Template...
Chris
you're right that this can only be done with the template but to create one I needed to go to:
Design --> Feature Design
and then under Templates:
Features and Technologies --> Controller --> WLANs --> WLAN Configuration
There I've created new template for WLAN and then deployed it to controllers.
Maybe that's better way to do it, when you have many controllers.
Tomasz
Always more than one way to skin a cat. You are looking at Lifecycle view, I gave you the option in Classic.
Yep, that explains a lot
Recognize Your Peers
