Prime Infrastructure 2.0 - SNMP location lost when collecting
Bart Mars
We've detected strange behaviour from our Cisco Prime Infrastructure. We did a upgrade from 1.3 to 2.0 last friday and all looked good and well. However, we noticed that our SNMP locations were missing from our network devices. With some research, we saw that the SNMP locations were in the startup-config, but not in the running-config. We also noticed that our LMSuser (which we use for identifying that Prime is logging into the switch) changed something in the config:
Oct  2 22:00:50 192.168.57.220 7566: Oct  2 22:00:49: %SYS-5-CONFIG_I: Configured from console by lmsuser on vty1 (172.20.250.1)
So we set the SNMP location on a couple of switches to test our theory. And the next evening when Prime does its collection routine, it removes the SNMP location again.
Is this a bug or is this a new setting in Prime?
Thanks in advance!
AFROJ AHMAD
Hi Bart,
This is the BUG :
PI 2.0 corrupts device config by doing snmp set for location after sync
CSCuj09556
Symptom:
Prime Infrastructure 2.0 corrupts a managed devices config by doing an SNMP Set for location after a device sync.
Conditions:
Workaround:
Add/sync  the device with RO community (to read the system location) and after  that, change the community in PI to RW with following snmp view:
snmp-server view SYS_exclude system.6.0 excluded
snmp-server view SYS_exclude iso included
snmp-server community
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Bart,
This is the BUG :
CSCuj09556
Symptom:
Conditions:
Workaround:
Thanks-
Afroz
