Prime Infrastructure 2.0 Software Deployment VSS Systems
John Capobianco
Good day -
Has anyone used the PI 2.0 Software Deployment with VSS systems like 6500 or 4500? Does it work? Does it upgrade the image in eFSU? Should VSS systems be manually updated?
Finally are there any guides or documentation on using PI 2.0 to deploy / upgrade images for platforms like 6500 / 4500 running VSS mode?
John
2 Accepted Solutions
AFROJ AHMAD
there is a Feature Enhancement BUG filed for VSS support
Unable to add or manage a 6500 in VSS in PI:
https://tools.cisco.com/bugsearch/bug/CSCuj09930/?reffering_site=dumpcr
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Simlarly we have a BUG for 4500 for VSS [
4500x in VSS pair is not fully supported in PI] :
https://tools.cisco.com/bugsearch/bug/CSCuh47582/?reffering_site=dumpcr
Thanks-
Afroz
5 Replies 5
AFROJ AHMAD
Thanks-
Afroz
AFROJ AHMAD
Thanks-
Afroz
Thank you!
Do you know if 3750X using Stackwise are supported? Can I point to a stack of 3750X and use PI 2.0 to upgrade the entire stack?
John
Hi John,
Yes ,3750x and 3850 Stack are supported for Image upgarde.
while Upgarding use ONLY .tar Image.
CSCuj31728 PI SWIM should not allow distributing bin images to stack switches
Thanks-
Afroz
