Prime infrastructure 2.2 and ACS 4.2
jbabio
So we are running into an issue where applying the task list (tacacs) from prime to ACS works for some but not others. What I mean is applying the list to a group within ACS. When I have the admin task applied to my group I can log in but not perform administration. If I remove it I cannot login. When Applying the settings to my individual account I can perform administration. Does anyone have an explanation for this behavior?
virtual-domain0=ROOT-DOMAIN
role0=Admin
task0=Run Job
task1=Device Reports
task2=Raw NetFlow Reports
task3=Network Summary Reports
task4=Discovery View Privilege
task5=Configure ACS View Servers
task6=View Audit Logs Purge Settings Access
task7=Administration Menu Access
task8=Network Topology Edit
task9=Compliance Reports Read Only
task10=Configure Lightweight Access Point Templates
task11=Config Archive Read Task
task12=Monitor Chokepoints
task13=Virtual Domains List
task14=View Compute Devices
task15=Monitor Third Party Controllers and Access Point
task16=Edit Device Access
task17=View Group Members
task18=Migration Templates
task19=Monitor Spectrum Experts
task20=Configure Autonomous Access Point Templates
task21=Audit Trails
task22=Client Location
task23=Delete Device Access
task24=TrustSec Readiness Assessment
task25=PnP Profile Deploy Read-Write Access
task26=Monitor Access Points
task27=Data Collection Management Access
task28=CleanAir Reports
task29=Configure Ethernet Switch Ports
task30=Mobility Service Management
task31=Swim Upgrade Analysis
task32=Help Menu Access
task33=Product Feedback
task34=MSAP Reports
task35=Search Access
task36=Details Dashboard Access
task37=Scheduled Configuration Tasks
task38=Configure WIPS Profiles
task39=Client Reports
task40=Services Menu Access
task41=Report Launch Pad
task42=Latest Config Audit Report
task43=Mesh Reports
task44=Swim Info Update
task45=View Audit Logs Access
task46=Design Monitoring Template Access
task47=Monitor Controllers
task48=Deploy Configuring Access
task49=View Job
task50=Software Updates UBF Upload
task51=Autonomous AP Reports Read Only
task52=Design Configuration Template Access
task53=PnP Preferences Read Access
task54=Security Reports Read Only
task55=SSO Servers
task56=Configure Switch Location Configuration Templates
task57=Configure WiFi TDOA Receivers
task58=Maps Menu Access
task59=Discovery CRUD Privilege
task60=Voice Audit Report
task61=Admin Dashboard Access
task62=Global SSID Groups
task63=PnP Deploy History Read-Write Access
task64=Wireless Dashboard Access
task65=WIPS Service
task66=Security Reports
task67=Application Server Management Access
task68=Monitoring Policies
task69=View Security Index Issues
task70=Swim Access Privilege
task71=Device Bulk Import Access
task72=Home Menu Access
task73=Approve Job
task74=Guest Reports
task75=Logging
task76=Device View configuration Access
task77=Swim Preference Save
task78=Delete and Clear Alerts
task79=Identity Search Engine
task80=Rogue Location
task81=Delete Group Members
task82=PnP Profile Read-Write Access
task83=Tools Menu Access
task84=Configure ISE Servers
task85=Config Audit Dashboard
task86=Virtual Domain Management
task87=Incidents Alarms Events Access
task88=Monitor Ethernet Switches
task89=CleanAir Reports Read Only
task90=Monitor Mobility Devices
task91=Configure Choke Points
task92=MSE Analytics
task93=Swim Delete
task94=Theme Changer Access
task95=Import Policy Update
task96=Design Endpoint Site Association Access
task97=Planning Mode
task98=Configure Menu Access
task99=Deploy Monitoring Template Access
task100=Ack and Unack Alerts
task101=View Alerts and Events
task102=RADIUS Servers
task103=Credential Profile Delete Access
task104=Edit Audit Logs Purge Settings Access
task105=Saved Reports List Read Only
task106=Run Reports List
task107=View CAS Notifications Only
task108=Monitor Clients
task109=Monitor Media Streams
task110=Maps Read Write
task111=Configure Access Points
task112=Mesh Reports Read Only
task113=Users and Groups
task114=Saved Reports List
task115=Swim Collection
task116=Device WorkCenter
task117=Configure Ethernet Switches
task118=Raw NetFlow Reports Read Only
task119=TACACS+ Servers
task120=Edit Job
task121=Autonomous AP Reports
task122=Performance Reports Read Only
task123=Delete Groups
task124=Performance Reports
task125=Configure Controllers
task126=Packet Capture Access
task127=Credential Profile Add_Edit Access
task128=WorkflowsReadWriteAccess
task129=Monitor Tags
task130=Scheduled Tasks and Data Collection
task131=MSAP Reports Read Only
task132=View Groups
task133=Delete Job
task134=Network Topology
task135=Troubleshoot
task136=Configure Templates
task137=System Jobs Tab Access
task138=System Settings
task139=Remove Clients
task140=Performance Dashboard Access
task141=Configure Config Groups
task142=Application and Services Access
task143=Inventory Menu Access
task144=Export Device Access
task145=High Availability Configuration
task146=License Center
task147=Add Group Members
task148=Manage and Monitor Servers Page Access
task149=mDNS Policy Admin
task150=Monitor Security
task151=Monitor Menu Access
task152=Track Clients
task153=Network Summary Reports Read Only
task154=Schedule Job
task155=Export Audit Logs Access
task156=Monitor Interferers
task157=Add Groups
task158=Guest Reports Read Only
task159=Swim Distribution
task160=Cancel Job
task161=PnP Preferences Read-Write Access
task162=Credential Profile View Access
task163=Modify Groups
task164=Report Run History
task165=Maps Read Only
task166=Compliance Reports
task167=Custom NetFlow Reports
task168=Disable Clients
task169=PnP Profile Deploy Read Access
task170=Configure Spectrum Experts
task171=Appliance
task172=Configure Mobility Devices
task173=Custom NetFlow Reports Read Only
task174=Monitor WiFi TDOA Receivers
task175=Health Monitor Details
task176=View Alert Condition
task177=Add Device Access
task178=User Preferences
task179=Config Archive Read-Write Task
task180=Configuration Templates Read Access
task181=Automated Feedback
task182=Configure Third Party Controllers and Access Point
task183=Email Notification
task184=License Check
task185=SSO Server AAA Mode
task186=Device Reports Read Only
task187=Swim Recommondation
task188=Identify Unknown Users
task189=Reports Menu Access
task190=TAC Case Management Tool
task191=Pause Job
task192=Discovery Schedule Privilege
task193=Client Reports Read Only
task194=Context Aware Reports
task195=ContextAware Reports Read Only
task196=Voice Diagnostics
task197=RRM Dashboard
task198=PnP Deploy History Read Access
task199=PnP Profile Read Access
task200=Ack and Unack Security Index Issues
task201=Pick and Unpick Alerts
task202=Auto Provisioning
Josh S
We were successfully able to get Prime 2.2 working with tac_plus without issues.  We utilized the task list at https://supportforums.cisco.com/sites/default/files/attachments/discussion/pi_tasks_for_tacacs.txt
You will need to put every task in quotation marks, and adjust domain, role, etc.
Edit: also some of the tasks are mispelled (i.e. acces vs access)
