Prime Infrastructure 3.0 Automatic archive configuration
ladislao2006
It is possible that a device can push an archive configuration in Prime every time that a user makes a "write" or "copy-running startup-config"?
2 Accepted Solutions
 I'd say no. What triggers archive is the schedule not events. What you can do is lower the archive interval for daily or hourly.
-If I helped you somehow, please, rate it as useful.-
Hello Flavio
Thanks a lot for your answer. In fact, I was looking information about this on PI docs and this is what I found which match with your answer. ;)
Hello Flavio
picpic
Perhaps it is in new versions, but now we can configure in our Cisco Switch "logging ipCiscoPrime" and configure in Cisco Prime that:
But, not working for me...
