Prime Infrastructure 3.10.1 replacement file
eglinsky2012
This is interesting. The 3.10.1 patch file has been replaced with a newer version (note the .25 now instead of .23 in the previous file name). I can't find any reference of this revision in the release notes, and since I already have the .23 version installed, I'm unclear if I should install the .25 version. I guess I should just wait until 3.10.1 U1 comes out (if it ever does), but does anyone have more information on this?
Screenshot from the notification email attached.
balaji.bandi
as per the output .23 gone .25 is now correct one, if you like to install, .25 you can do that, take backup as normally we do and apply .25.
BB
alexhunter
What about if you are getting the following error when trying to update to .25 even though I have .23 installed? (See attached).  I have tried to restart our Prime server but I keep getting this error.
Anyone else come across this?
