Prime Infrastructure 3.10.2 and Device Pack 1
stayd
I made upgrade PI from 3.10 update 1 with Device pack 1 to 3.10.1 and later to final 3.10.2.
I saw the release notes:https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10-2/release_notes/bk_cisco_prime_infrastructure_3_10_2_release_notes.html
and its important notes:
When your system is running with Prime Infrastructure 3.10 or 3.10 Update 01 or 3.10.1 and upgraded to Prime Infrastructure 3.10.2, please do not install the Prime Infrastructure 3.10 - Device Pack 1 separately. By default, the Prime Infrastructure 3.10 - Device Pack 1 is installed during upgrade of Prime Infrastructure 3.10.2
I did not install this patch seperatly. I got the server which has already installed this device pack with.
I installed over 3.10.1 and later I had to install 3.10.2.
Now after reload I am getting info from PI, there is new update the same Device Pack 1 from April same year.
I have tried to install it and I got information that Device Pack 1 is already installed in 3.10.2.
What can I do with this now ?
It seems a bug. Important note describes different situation from mine. I had at the beggining already Device Pack 1 installed.
Nowhere in release notes is description how to deal with this.
2 Accepted Solutions
So TAC case was finished with this BUG ID: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb78348
you have to put the ID again to search window, than you will get it.
It has the status open severity 3.
Later clearing cache and cokies remove this issue.
6 Replies 6
marce1000
 - These kind of problems,  and also because your Prime versions are fairly recent , can most of the time only be handled in cooperation with Cisco TAC.
 M.
Leo Laohoo
Contact Cisco TAC.
Good luck!
yeah will do
stayd
I have found out new issue:
