Prime Infrastructure 3.2 Discovery issue
RDavidov
Hello
I have the following problem:
Have a lot of Cisco devices on the network, each one has IP addresses on the Vlan interfaces (for example 1.1.1.1) and on physical interfaces from ISP (2.2.2.2)
I run Job Discovery with range 1.1.1.1 The problem is that after Discovery, devices show up in Monitor / Managed Elements / Network Devices with 2.2.2.2 IP, which i cannot even change.
Does anyone have any ideas on this?
Thank you very much for your efforts
Raul
John Palmason
Level 4
Level 4
Do you source the ip that SSH or SNMP use from the network devices?    For example, we use PI 3.1 and we force the ip we use to talk back via either the loop back address of a management address.
Router example
ip ssh source-interface X
Switch example
ip ssh source-interface Vlan10
