Hello
I have the following problem:
Have a lot of Cisco devices on the network, each one has IP addresses on the Vlan interfaces (for example 1.1.1.1) and on physical interfaces from ISP (2.2.2.2)
I run Job Discovery with range 1.1.1.1 The problem is that after Discovery, devices show up in Monitor / Managed Elements / Network Devices with 2.2.2.2 IP, which i cannot even change.
Does anyone have any ideas on this?
Thank you very much for your efforts
Raul
