Prime Infrastructure and APIC EM support for ACI Swithes.
faizal_vi
Is it possible to add the the ACI 9K switches to the PI(3.X) and APIC-EM(1.6)?
Faizal
ChrisMac70330
Hi, you can add them but there will be only partial information collected, for e.g config will not be available.
Please check as well if it's in the supported devices list, for example my 1st gen leafs are.
marce1000
 - FYI  : https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
 M.
