Prime infrastructure---Firewall
abdulkarim041
Level 2
Level 2
Does Cisco prime infrastructure has the support for firewall?
AbdulKarim
6 Replies 6
Mark Malone
it doesn't have a dashboard for firewalls if that's what you mean ? or if you mean can it see and poll manage ASAs yes it can but it doesn't have a specific integration like some other features like below
it does have an ISE/APIC/ACS/IWAN and WAAS integration
Thanks Mark
I just want to monitor Firewalls physical interfaces or its availability. Is it possible?
BR
Yes that's fine I have all my ASAs in Prime and can access them from Prime collect stats etc and push configs, obviously though Prime only supports Cisco so no fortinets or Palo Altos etc
Thanks Mark,
Then Please let me know how i can put the licence for firewall by using CCW?
BR
I want to know how I can select licence ASA from CCW tool. Fr reference file is attached.
I have to make BoQ for a client.
Sorry I have never used CCW , our presales guys and our Cisco account manager  would use that and provide them to us ,  I purely work in tech side so I cant advise on that bit only the tech bits,  how to activate license get things working  etc
