08-19-2013 05:16 PM
Hi all,
We have an existing WCS setup (7.0.240.0).
I have built up a Prime Infrastructure server running release 1.3.0.20.
Originally I was going to look at migrating our existing WCS configure but the two stage process (WCS -> NCS -> Prime) looked prone to errors. Dediced to skip it and concentrate and building up from blank slate.
The only exception was the floorplan maps for Wifi, I was able to export these straight from WCS to Prime without any hicups.
I then added our main WLC and assigned the APs to the correct maps.
Sweet!
Now I would like to get the templates going for our WLCs as i have a couple more to deploy. The issue is that I dont want to manually configure templates in Prime. WCS had the ability to import templates from an existing WLC, a goldern WLC config. I cant seem to find any doco indicating this ability. Anyone come across something similar or another way I might acheive?
Cheers
Chris
Solved! Go to Solution.
08-19-2013 08:05 PM
From the Classic Theme:::
Go to Configure> Controllers, Select the Controller(s), select Discover Templates from Controllers
08-19-2013 08:05 PM
08-27-2013 04:48 AM
Thanks Rob, worked great.
