Prime Infrastructure Template deployment problem
sachazufferey
Community Member
I have a problem with a template, when I want to deploy it, I can't see any equipment in the devices tab... Here are some captures to explain :
I have other templates and no problem with them... I can't understand why... I use Prime Infrastructure v 3.2.0 (Virtual Appliance)
Thank you in advance for your help.
Sacha
pieterh
PI checks if the commands can be executed on devices.
It can also mean, according to PI, these commands are allready present on all known devices.
you can try what PI does shows if select this device for "undeploy"?????
I add a new test stack without any config to check this problem but I can't deploy the template either...
When I create a new template, the list is still empty 😞
" without any config " -> no ntp server configured ?
so PI cannot execute "no ntp server ....."on this switch
=> it is not elegible for selecting
Brett
Level 2
Level 2
Is the device being fully managed in Prime, and showing reachable and pingable?  Usually you won't see the device if the device type is incorrect or if the device is unmanaged.  If it was something wrong with the commands you would get to the preview tab and an error would be present there.
