archive lms 3.1
h_hammad
How can view the scheduled archiving job in lms 3.1  ?
Thanks for the help
Vinod Arya
Sheduled Jobs should be available under Job browser and ususally a sched job will run in instances. If the job is xxxx than every time it runs xxxx.1, xxxx.2,...,..xxxx.yy should be the latest sched job.
If the job purge is running regularly it may be posible the previous instances are purged and you are not able to see the first instance xxxx.1.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
