Prime System Jobs (Status) arent working right
danielEr.
we got a Problem with the System Jobs - Status.
I think since they were migrated from the Background Tasks to the Job Dashboard they got problems to start automatically.
Every Job got a Shedule Time and a next Start Time is displayed but only three Jobs are working fine.
All other System Jobs (Infrastructure, Inventory and Discovery Jobs and Wireless Monitoring) works fine.
Any ideas? Or the same Problem? Is there already a Bug reported?
I forgot:
We have Prime Infrastructure (Build: 3.1.0.0.132)
steiostb1
Ive got the same problem which results in that i cannot use the search function properly. Jobs under Wireless Monitoring is affected too. I have tried to edit the schedule to more often and paused and then resumed the job. Still i have to manually run the jobs for them to start.
The lastet mantaince patch is even installed - PI_3_1_2-1.0.53.ubf
show version
Cisco Application Deployment Engine OS Release: 3.1
ADE-OS Build Version: 3.1.0.001
ADE-OS System Architecture: x86_64
Copyright (c) 2009-2016 by Cisco Systems, Inc.
All rights reserved.
Hostname: prime-prod02
Version information of installed applications
Cisco Prime Infrastructure
Version : 3.1.0
Build : 3.1.0.0.132
Critical Fixes:
PI 3.1.2 Maintenance Release ( 2.0.0 )
Device Support:
Prime Infrastructure 3.1 Device Pack 1 ( 1.0 )
prime-prod02/admin#
