Problem after setting the enable privilege level to 7
ankit.gupta311
I have set the admin enable privilege level to 7 and have set the password. The configuration has been saved with wr. Now when I am entering the enable password, I am not able to go to the config mode, neither see the running configuration. Is there any way to sort this out. Can I change the privilege level ?
balaji.bandi
Do you have any other user which has level 15, is the only option or you need to go to reset password procedure.
BB
BB
