Problem after upgrade a PRIME-NCS-APL-K9 from version 1.1.0.58 to Prime Infrastructure 1.2
kuweb
I have upgraded a PRIME-NCS-APL-K9 from version 1.1.0.58 to Prime Infrastructure 1.2
First I have installed the Path "ncs_patch-1.1.0.58-upgrade-pi_1.2.tar.gz" and then the
"PI-upgrade-bundle-1.2.0.103.tar.gz".
after the upgade I have got the Message "Upgrade Successful".
Now when I start the NCS i get the following error message
egghead/admin# ncs start
Starting Network Control System...
Unable to verify hardware.
This may take a few minutes...
Health Monitor is already running.
Failure during Network Control System startup. Check launchout.log for details.
In the launchout.log are this messages:
Starting Health Monitor as a primary
Checking for Port 8082 availability... OK
truststore used is /opt/CSCOlumos/conf/truststore
Starting Health Montior Web Server...
Health Monitor Web Server Started.
Starting Health Monitor Server...
Health Monitor Server Started.
Starting Remoting Service: Reporting Server
Checking for running servers.
00:00 Check complete. No servers running.
Starting Server ...
The Report Server startup script is already running waiting for report server to start
have anyone an idea whats wrong?
thank you for your help
Kurt
8 Replies 8
Patrick Graf
Im having exactly the same issue with a brand new NCS Appliance at the first start.
Did you get any answer ?
I allready did a "ncs db reinitdb" it did not help.
The appliance never starts completely.
All I'm getting is:
OGNCS01/admin# ncs status
Health Monitor Server is starting.
Reporting Server is Starting
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is stopped.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
status
After about one hour I'm having the same logs as you.
Patrick
I have the same problem.
An error message with a new NCS, i follow this steps
To get it back up and running do the following from the CLI.
1. Stop the NCS
2. Run 'ncs db reinitdb'
3. Start the NCS
but didnt work and when i put the command "show ncs status"
all the services is in stopped mode.
i have  the same problem
NCS/admin# ncs status
status
I try it
1. Stop the NCS
3. Start the NCS
but the status is the same
Richard Atkin
Level 4
Level 4
Format and re-image the box straight on to v1.2 / 1.3?
It's a new NCS Appliance at the first start.
Actually i have 1.2.0.103 version, which image do i have to download?
If you have maintanance support you can download this sw from cisco support web.
Unfortunately, we didn't have this then we bought this recovery DVD media PI12-MEDIA-K9=  and installed this again.
kuweb
This is a way to fix this problem.
login to ncs server as oracle user like the following from the cli root user
su - oracle
. ./oracleenv
sqlplus /nolog
connect /as sysdba
startup mount;
exit
rman
connect target /
crosscheck archivelog all;
delete expired archivelog all;
exit
sqlplus /nolog
connect /as sysdba
alter database open;
exit
stop and start ncs
