Problem configuring IP SLA using SNMP
Roycey Cheeran
Community Member
I am trying to configure IP SLA on a Cisco device using SNMP. No matter what I do the rttMonCtrlAdminStatus changes to 1 even though I set it to 4.
The device is  - Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
My snmpset command is as follows
snmpset -v2c -c xxxxxx  100.252.0.12  1.3.6.1.4.1.9.9.42.1.2.1.1.9.1 i 4 1.3.6.1.4.1.9.9.42.1.2.1.1.4.1 i 1 1.3.6.1.4.1.9.9.42.1.2.2.1.1.1 i 2 1.3.6.1.4.1.9.9.42.1.2.2.1.2.1 x 'AC 10 1B 06' 1.3.6.1.4.1.9.9.42.1.2.2.1.6.1 x '0A FE 00 02' 1.3.6.1.4.1.9.9.42.1.2.5.1.2.1 t 1 1.3.6.1.4.1.9.9.42.1.2.5.1.1.1 i 214748364
SNMPv2-SMI::enterprises.9.9.42.1.2.1.1.9.1 = INTEGER: 4
SNMPv2-SMI::enterprises.9.9.42.1.2.1.1.4.1 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.42.1.2.2.1.1.1 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.42.1.2.2.1.2.1 = Hex-STRING: AC 10 1B 06
SNMPv2-SMI::enterprises.9.9.42.1.2.2.1.6.1 = Hex-STRING: 0A FE 00 02
SNMPv2-SMI::enterprises.9.9.42.1.2.5.1.2.1 = Timeticks: (1) 0:00:00.01
SNMPv2-SMI::enterprises.9.9.42.1.2.5.1.1.1 = INTEGER: 214748364
Things look fine here. Now when I try to cross verify
snmpwalk -v2c -c xxxxxx 100.252.0.12 1.3.6.1.4.1.9.9.42.1.2.1.1.9
SNMPv2-SMI::enterprises.9.9.42.1.2.1.1.9.1 = INTEGER: 1
The rttMonCtrlAdminStatus shows as 1.
Is there something that I am missing out?
Joe Clarke
This is normal.  You set the row status to createAndGo, and because everything was configured properly, the row transitions to active(1) automatically.  This what you want.
