10-17-2012 03:53 AM
Hi all,
we have problem importing IOS (details are in the subject) in LMS 4.0.1. The error we obtain is: "SWM0009: Could not extract image attributes. Check whether it is supported by Software Management". The MD5 of my local file is the same of the one reported by Cisco site (http://www.cisco.com/cisco/software/release.html?mdfid=282201754&softwareid=280805680&release=15.2.4S&flowid=843).
No helps reading https://supportforums.cisco.com/message/639266.
Any suggestions?
Thanks in advance.
10-18-2012 12:47 AM
Please check the tag it may be helpful to you..
Plese rate helpful tags
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
10-18-2012 03:53 AM
Thank you.
Regards.
Rolando
10-18-2012 12:58 AM
If it is an option, try cisco.com option and try to add it to repository.
10-18-2012 03:54 AM
Unfortunately is not an option.
Thank you.
Rolando
10-18-2012 04:27 AM
If the image is already running on one of the device, try importing it. Just to make sure no issues with the image.
As you are trying to copy it from the local file system, try to give file a permission rw to all users. A new download from cisco.com is recommended with correct MD5 value and try to add it to repository again.
