Problem installation client for DCNM
lbellicaud
I installed DCNM on a server 2003 64bit for administration of 4 Nexus 7000.
The installation went normally.
Now when I want to join server in http:@ipserver:8080/dcnm-client/index.htm, he always asks me to install java although I have version 1.6.0_24.
If i click on the button "launch DCNM client", he load java web start, i have application error "requesting java1.6.0_21" & unable to load application.
With another computer it's same and in server item.
thank for your help
Nael Mohammad
Level 5
Level 5
You are not using the correct version of the JRE. Uninstall the version you have, go to DCNM so it can push out the correct version to your workstation and don't upgrade your JRE automatically.  Below are the requirements:
Java Requirements
Cisco DCNM is a Java-based client-server application. The Cisco DCNM 5.1 server and client support Java JRE 1.6.0_21. The installation process uses Java version 1.6. If your system does not have that version of Java, the installation process will download it to the DCNM_root_directory/java/jre1.6 directory.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/dcnm/release/notes/dcnm_5_1_relnotes.html#wp61630
Nael Mohammad
Level 5
Level 5
Java Requirements
it's ok thank
